7204 SLB
Answered Question
Sep 17th, 2009
I have one router Cisco 7204 con IOS 12.4(15)T3, with the service SLB configure on it.
I need to know if the Cisco 7204 support NAT source and what IOS version I need for support this feature.
Thanks!
best regards,
Jorgelina
Correct Answer by Jon Marshall about 7 years 5 months ago
Jorgelina
So you are searching for client NAT in SLB. Well according to Feature Navigator none of the 12.4T train support that feature. 12.2SB does support client NAT but you will need to use Feature Navigator yourself because if you need to make sure that the IOS version you choose not only supports SLB client NAT but also all the other features you are currently using on your router -
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Jon
Overall Rating: 5 (1 ratings)
Jon Marshall Thu, 09/17/2009 - 08:11
Jorgelina
Have you tried to configure NAT and it won't work ?
Because i would have though NAT would be available in all feature sets. Which feature set are you running and are you saying it does not support NAT ?
How is the NAT issue tied in with the SLB ?
Jon
jorgelina.abraham Thu, 09/17/2009 - 08:34
Hi Jon:
I am searching the feature NAT source.
I want to hide or do NAT of the address of the client to the servers.
My intention is not use an ip nat source , but on the configuration of the server farm (ip slb serverfarm NAME), enable the option nat client Pool_Name.
This configuration go inside to the server farm parametrization.
Thanks!
Correct Answer
Jon Marshall Thu, 09/17/2009 - 08:48
Jorgelina
Jon
