Saurabh Verma Thu, 09/17/2009 - 07:29
I haven't seen LED status to be red before. It should flash green when the CF card is accessed (it should not be lit if the CF card is not being accessed). Are you seeing this as red? Is this for the factory installed CF?
Saurabh
ThomasBond_2 Thu, 09/17/2009 - 07:59
Red Led status was a example ..
When the CF is green blinking is a normal operation. But when the CF LED is always Green ? What's UP? What is the meaning?
Steven DiStefano Thu, 09/17/2009 - 08:03
green steady means something is reading from it or writing to it.
With no activity, I notice it flashes slowly (like 1x/second)
I'm also intereste if thats the Flash card that came with the system as well?
ThomasBond_2 Thu, 09/17/2009 - 08:25
Yes the flash card in the UC500, is the original. When the LED is always in green mode, the telefony service don't works, I try connect to CONSOLE port and the following message is showed: %% Low on memory; try again later. I restart the UC and the services works fine again !!!
Steven DiStefano Thu, 09/17/2009 - 08:43
Sounds like your flash is full ;-(
You may want to open a case and remove some files that you dont use.
I suggst TAC for this because this could be dangerous.
Usually phone loads that you know you dont use for sure, can be removed.
ThomasBond_2 Thu, 09/17/2009 - 08:55
Thanks Mr. Steve DiStefano,
and another messages is :
Memory allocation of 20000 bytes failed from 0x801C6890, alignment 0 Pool: Processor  Free: 3341516
Cause: Memory fragmentation Alternate Pool: None  Free: 0  Cause: No Alternate pool
Saurabh Verma Thu, 09/17/2009 - 08:58
This message is being generated by the system. I would recommend that you open a TAC case. TAC should be able to find any defect (or config issues) associated with memory allocation.
Saurabh
