ARP Table
Answered Question
Sep 17th, 2009
I can reduce the size of the ARP table ?. The command show arp sumary, show 300000 address.
Router 2800.-
Correct Answer by Giuseppe Larosa about 7 years 10 months ago
Hello Ricardo,
the right question is whay my router has built a so big table?
check if you have for example a default route towards internet link using interface name instead of an ip address next-hop.
if so your device is using proxy-arp for every internet destination and this is not efficient.
the change in this case is to configure a default static router with an ip address next-hop that of provider router.
Another possibility is that there is an attack by a connected device sending a lot of gratuitous ARPs to your device.
Hope to help
Giuseppe
Overall Rating: 5 (2 ratings)
Correct Answer
Giuseppe Larosa Thu, 09/17/2009 - 08:05
  • Hall of Fame,
    Founding Member
Hello Ricardo,
Hope to help
Giuseppe
