SIP Trunk Debug
Sep 17th, 2009
Hey Guys,
I am having some problems with SIP trunks going to a Motorola device. Are there any debug commands I can use to check the status of my sip trunk or any other trouble shooting tools I can use to get through this problem. Thanks for your help. Let me know if you need additional information.
Paolo Bevilacqua Thu, 09/17/2009 - 09:33
  • Hall of Fame,
    Founding Member
A SIP originating from what ?
CM, CME ?
parshah Thu, 09/17/2009 - 10:08
  • Cisco Employee,
For SIP trunk from CUCM to Motorola device, you will need to look at the callmanager service traces. You need to enable SIP traces in the serviceability page and collect the traces using RTMT.
gearmisner Thu, 09/17/2009 - 11:53
I was looking at the serviceability page and I did not see a place to enable SIP traces. Is it called something else or should it be pretty obvious?
