Extension Mobility Vs Hard Phone
dvanzee
Level 2
Level 2
I was wondering if I could get everyone's opinion on the advantages of using a full deployment of Extension mobility vs a full deployment of hard phones. Our company has been rolling out each of its sites as EM. However I do not believe everything needs to be setup as EM and it should be used as the exception rather than the rule. Thoughts are welcome.
2 Accepted Solutions
htluo
Level 9
Level 9
Extension Mobility is usually used for two purposes:
1) Mobility
If the user has to move around pretty often, EM would be a good solution.
2) Security (or toll control)
If every user logout from EM before leaving the office.
Michael
http://htluo.blogspot.com
Rob Huffman
Hi Daniel,
Hope life is treating you well my friend!
I tend to agree with you that EM should be the "exception rather than the rule" in most cases. If users are in open or "shared" bullpen style areas or if they need to move between desks/workspaces then EM is a perfect choice. If users have permanent offices and secure workspaces then EM seems like overkill to me. A mix and match solution seems like a better idea, why make all users go through the whole login/logout procedure when they are always at the same desk? Doesn't seem like a great, "user friendly" plan to me.
Just my 2 cent$
Rob
htluo
Level 9
Level 9
1) Mobility
Michael
Rob Huffman
Hi Daniel,
Just my 2 cent$
Rob
Thanks to both of you for your imput.
