Is it posiible to place a call from certain "calling number" to a specific
Sep 17th, 2009
I need to "calling number 199 and 200" can use only dial-peer voice 1 pots and "calling number 250 and 300" can use dial-peer voice 2 pots. Is it possible?
USERS-AVAYA-E1-Cisco 2801+VIC2-4FXO + IPVOICE
Thank you.
Wilson Samuel Thu, 09/17/2009 - 08:42
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, July 2015
In order to go ahead with your question, please also provide the following info:
1. Is it H.323 implementation of Gateway?
2. or Is it MGCP?
3. Whats the UCM version you are using?
SludnevTN_2 Sun, 09/20/2009 - 20:51
Thank you for your reply. Anyway. that did not help me. Let me explain again my task.
I have 4 FXO ports and 2 PRIs ports.
First PRI is external at looks at SP1.
Second PRI is internal at looks at Avaya G650. Users are behind this PBX.
4 FXO pots looks SP2.
1. If a call came from 2nd PRI with source number 500 or 550 and destintation 989......... it should forwarded to FXO1.
2. If a call came from 2nd PRI with source number 300 or 350 and destintation 989......... it should forwarded to FXO2.
3. If a call came from 2nd PRI with source number 200 or 250 and destintation 989......... it should forwarded to FXO3.
And so on.
First PRI is used for any source number and it's destination pattern is 983952......
I have read you link but...it seems to me that I am stupid today....no ideas.
Thank you anyway.
paolo bevilacqua Mon, 09/21/2009 - 00:39
  • Hall of Fame,
    Founding Member
See:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801bc341.shtml
Note, since you cannot configure incoming DP voip for ephones, you will have to apply the translation profile under ephone-dn or ephone-dn-template, make sure it matches only called numbers to PSTN.
Philip Denton Wed, 02/15/2012 - 04:45
Paolo,
Is there any reason the information contained in the link you provided wouldn't also work for an H.323 gateway that needs to route outbound traffic based on calling number?
I'm running CUCM 7.x so would it be preferable to use Partitions and CSS' to "tag" outbound calls by manipulating their ANI before they hit the H.323 gateway?
Phil
paolo bevilacqua Wed, 02/15/2012 - 07:08
  • Hall of Fame,
    Founding Member
It actually easier to manipulate called number in partition/css.
That will allow to use basic DP config to route calls the way you want.
Philip Denton Fri, 02/17/2012 - 05:39
Understood, but I need to manipulate callING number.  Is that easier in PT/CSS/DP also?
Edit: Otherwise I'm thinking of using "answer-address" to grab incoming calls and prepend a # or something, then use forward-digits on the outbound dialpeer to strip the # back off on egress.
