WLAN Controllers 4400 and 5500
Answered Question
Sep 17th, 2009
Hi!
Can I mix WLAN 4400 and 5500 controllers in the same WLAN infrastructure? Are they "compatible" between each other?
Thanks!
Correct Answer by Rob Huffman about 7 years 8 months ago
Hi Martin,
Yes, you can mix/match the 4400 series and 5500 series :)
Cheers!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Thu, 09/17/2009 - 09:14
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Martin,
Cheers!
Rob
Trending Topics - Security & Network
