09-17-2009 11:59 AM
Good day.
I have a 2821 with following hardware but i'm unable to begin the configuration of the VWIC for some reason. I thought it was IOS related but i'm using the same version of code else where.
Version:
c2800nm-spservicesk9-mz.124-25b.bin
Hardware config:
C2821 Motherboard with 2GE and integrated VPN Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time 00:01:05 ago
EEPROM contents at hardware discovery:
Hardware Revision : 1.0
Top Assy. Part Number : 800-26921-04
Board Revision : E0
Deviation Number : 0
Fab Version : 03
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 87
Hardware date code : 20090709
MAC Address block size : 32
CLEI Code : COMV410ARA
Product (FRU) Number : CISCO2821
Part Number : 73-8853-05
Version Identifier : V05
EEPROM format version 4
PVDM Slot 0:
48-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 4.0
Part Number : 73-8540-05
Board Revision : C0
Fab Version : 04
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-48
Version Identifier : V01
WIC Slot 0:
VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1
Hardware Revision : 0.0
Top Assy. Part Number : 800-22628-05
Board Revision : C0
Fab Version : 04
RMA History : 00
Product (FRU) Number : VWIC2-1MFT-T1/E1
I've tried all of the following but nothing seems to work.
WIN-DC-VG01(config)#network-clock-participate ?
aim AIM Module
slot Network Module Slot
wic WIC Module
WIN-DC-VG01(config)#network-clock-participate slo
WIN-DC-VG01(config)#network-clock-participate slot ?
<1-2> Slot Number
WIN-DC-VG01(config)#network-clock-participate slot 1
Slot is empty or does not support clock participate
WIN-DC-VG01(config)#network-clock-participate slot 2
WIN-DC-VG01(config)#network-clock-participate wi
WIN-DC-VG01(config)#network-clock-participate wic ?
<0-3> Slot Number (physical)
WIN-DC-VG01(config)#network-clock-participate wic 0
WIC slot is empty or does not support clock participate
WIN-DC-VG01(config)#network-clock-participate wic 1
WIN-DC-VG01(config)#network-clock-participate wic 2
WIN-DC-VG01(config)#network-clock-participate wic 3
I see that i only have slot 1 and 2 available and the 'sh diag' references slot 0...not sure why.
Thanks.
Solved! Go to Solution.
09-17-2009 04:28 PM
It looks like you need to enter the "card type" command to specify whether this is a T1 or E1 card.
-nick
09-22-2009 02:34 AM
I think the config help only shows arbitary values anyway
09-17-2009 04:28 PM
-nick
09-18-2009 06:46 AM
Worked perfectly thank you very much!
09-22-2009 02:34 AM
