voip lab
Sep 17th, 2009
I just earned my CCNA-voice and I would like to set up a lab for next CCVP. any cheap set up or any afordable setup that I can use. I am asking for your opinion
Brandon Svec Fri, 10/02/2009 - 17:47
I have run CME via GNS3 successfully and also installed CUCM with VMWare. These are both free options. If you want hardware then you will need to shop around on ebay, etc..
Did you pass CCNA Voice without any lab?
kechengpc Wed, 10/21/2009 - 00:30
I am interested in voice labs. Could you explain your voice labs?
Walter Solano Fri, 08/06/2010 - 15:58
The best way will be using VMWare, GNS3, CIPC that its the cheapest configuration that you can have to practice for the CCVP exams, regarding labs the use you imagination try to do everyhing that you can find in books and more .
Please rate this post if was helpful
Walter Solano
UCCX & Communications Express Specialist
