3750E IOS
Sep 17th, 2009
  • Bronze, 100 points or more
Hi all,
Can someone give me an idea of an extremely stable code for the following model (in a stacked configuration):
Switch Ports Model SW Version SW Image
* 1 54 WS-C3750E-48PD 12.2(50)SE3 C3750E-UNIVERSAL-M
2 54 WS-C3750E-48PD 12.2(50)SE3 C3750E-UNIVERSAL-M
3 54 WS-C3750E-48PD 12.2(50)SE3 C3750E-UNIVERSAL-M
4 52 WS-C3750-48P 12.2(50)SE3 C3750-IPBASE-M
There is a 3750 non E series switch in the stack, will that cause problems?
Anyway, we're having issues like:
- range command is really slow
- autoqos command errors out
- cannot save config
Not sure if this is a bug of if the E's and non E's don't play nice.
Any advice/help very welcome!!!
Brad
Overall Rating: 3 (1 ratings)
Leo Laohoo Thu, 09/17/2009 - 16:10
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hi Brad,
Unfortunately, there's no "extremely stable" code. I'm using 12.2(46). Mixing E to non-E's, just make sure you are using the same version and the same feature.
Before you upgrade or downgrade, make sure you read the release documentation to make sure you are not jumping into an firmware which may cause some potential issues to your network.
bmcginn Thu, 09/17/2009 - 16:41
Thanks for the advice Leo.
Appreciated.
Brad
Leo Laohoo Thu, 09/17/2009 - 17:41
  • Hall of Fame,
    2017 LAN, Wireless
No worries mate.
