Copying IOS from Rtr to Rtr
Answered Question
Sep 17th, 2009
I used to copy an ios from routerA to a tftp server, then back up to routerB. Is there a way to copy a ios directly from router to router? Any technotes would be apprecited.
Correct Answer by Jon Marshall about 7 years 4 months ago
David
Yes, you can use the tftp-server command, see this link for full details -
http://www.cisco.com/en/US/docs/ios/fundamentals/command/reference/cf_t1.html#wp1019519
Jon
Correct Answer by Leo Laohoo about 7 years 4 months ago
Yes.
1. Ensure routerA can ping routerB and vice versa.
2. If you want to copy ios from routerA to routerB, in routerA make sure you type the command in the configuration: tftp flash:
3. In routerB, copy the IOS across.
Hope this helps.
Overall Rating: 5 (2 ratings)
Correct Answer
Leo Laohoo Thu, 09/17/2009 - 15:21
Yes.
Hope this helps.
Leo Laohoo Thu, 09/17/2009 - 17:40
Thanks for the ratings David. Saaay, weren't you with EDS before?
