platinum_jem Thu, 09/17/2009 - 20:37
aaa new-model
aaa authentication login default local enable
username user1 password mypassword
#### Below is the enable password ###
enable password mypassword
The above command will set user logins for both telnet and SSH.
Hope this helps.
vinothlb1 Thu, 09/17/2009 - 20:58
without enabling
aaa new-model
how to set username and password for telnet and ssh
carl_townshend Fri, 09/18/2009 - 02:51
hi there
what is the, enable bit for at the end of the following command ?
cheers
pompeychimes Fri, 09/18/2009 - 03:02
  • Bronze, 100 points or more
Means that you can use the enable password to login if for some reason there is no UN or PW configured.
