Call manager 7.01 - Route Pattern - Block Offnet
Sep 18th, 2009
I have this RP , 011.91!, predot.
The RL goes to the Standard local RG in call manager 7.
This going via a MGCP gateway to PSTN.
I does not even go out of Call manager.
Dialing 0119- the 4th digit - 'your call cannot be completed....'
RTMT:
DialedNum=tn=0npi=1nd=011pi=0si1 requestID=0 DigitAnalysisComplexity=0
000009553| 2009/09/19 00:23:49.885| 002| SdlSig | DaRes | info_da | Cdcc(2,100,171,26) | Da(2,100,164,1) | (2,100,37,1).287-(SEP00258417961A:10.10.200.250)| [R:NP - HP: 0, NP: 0, LP: 0, VLP: 0, LZP: 0 DBP: 0]CI=47096851 Block ExclusivelyOffNetPotentialMatchesExist OnNetrequestID =0
I am not sure why there is this Block ExclusivelyOffNetPotentialMatchesExist OnNetrequestID =0 ?
The clusterwide service parameter is not even set to block offnet.
Any help appreciated.
Paul
KonradStepniewski Fri, 09/18/2009 - 03:43
  • Silver, 250 points or more
Hi Paul,
What about RP configuration? There is option to route pattern or block it, I would check it first.
K.
PAUL CHEN Fri, 09/18/2009 - 05:45
Hi Konrad,
Route the pattern is selected. CSS and partitons are also correct.
Not sure what is wrong yet, still trying to troubleshoot.
Paul
Wilson Samuel Fri, 09/18/2009 - 04:43
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, July 2015
Could you please check the concerned CSS and the Partitions and possibly any Router Filters, as well.
Sam Wilson
PAUL CHEN Fri, 09/18/2009 - 10:19
Hi Sam,
There was a 4 digit RP with urgent priority checked. I unchecked that and it worked.
The RTMT was showing some misleading debug.
Thanks.
