Backup COMPLETE ASA Configuration
Sep 18th, 2009
Via ASDM I can backup the complete configuration of my ASAs.
Complete means, not only running-/startup-configuration, but certificates, customization, DAP, plug-in, translation-tables and so on.
Two questions to you:
1) Why can't I do that on ASAs with multiple contexts?
2) How can I do that on CLI, which commands do I use to get xmls, certs...
We don't want to do the backup via ASDM, but automate it via CLI.
Thanks for any advice
Stephan
kailey_gauthier Fri, 10/30/2009 - 10:23
I don't believe this is a full answer but I hope I can help you somewhat.
you'll need a tftp server that can communicate with the ASA.
use the copy command on the CLI to backup files to the tftp server
example: copy disk0:folder/file.xml tftp://nameorip/optionalfilename.xml
two files that are important (beyond the cli's configuration) are dap.xml and data.xml
you can see their locations (and all other files) by typing "show disk0:" (or whatever your storage is named)
