URL sticky on the ACE
Sep 18th, 2009
I need to configure sticky on the base jsessionid in the following URL:
GET /forms/lservlet;jsessionid=0ad20c2630d669f096be228c4e28b46bdfab35277e64.e34SahePax0Kby0MahqPbNyPbx50n6jAmljGr5XDqQLvpAe?ifcmd=getinfo&ifhost=PC7&ifip=10.210.200.17 HTTP/1.1\r\n
I configure the following on the ACE:
sticky http-cookie jsessionid URL
cookie secondary jsessionid
replicate sticky
serverfarm FORMS
will it work??? I don't know if the cookie in the URL can start after ";" usually the cookie start after "?" ?
Thank you
Roman
koltl-gold Wed, 09/30/2009 - 22:26
Capture the traffic and check if the cookie appears in the HTTP header too (Set-Cookie: JSESSIONID=xxx). If so, try to match that one. In my Oracle experience the cookie name was all upper case.
Peter
