09-18-2009 04:42 AM - edited 03-15-2019 07:48 PM
I'm struggling to find the part number to use for a Unity 4.x to Unity 7 upgrade. The original order was licensed as UNITYV4-50USR, does anybody know what part number I should be looking at?
Any idea of inidicative list price too pls?
Jed
09-19-2009 01:48 AM
See, this is the list of supported hardware for unity 7.X
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/7x/support/7xcusupp.html#wp465589
could you explain your question as for what part number you looking for?
Hope above helps!
09-19-2009 01:59 AM
sorry, it's probably not clear what I'm asking for!
Normally to upgrade a software component there is an upgrade part number for the software itself. I'm looking to upgrade Unity from version 4 to version 7, probably on the same hardware platform. I just need to know the part number for the software upgrade as no UCSS has been purchased in this instance.
jed
09-19-2009 02:16 AM
i guess if you are upgrading unity to unity 7 on a supported hardware then you can download the upgrade material from CCO,
I searched on CCO and find the stuff there under download software,
they also have all microsoft updates and ES available
