L2PT guard
Sep 18th, 2009
I have this situation:
SWITCH1---SWITCH2---ROUTER
SWITCH1 port toward SWITCH2 has configuration:
Interface GigabitEthernet1/0/1
switchport access vlan 333
switchport mode dot1q-tunnel
l2protocol-tunnel cdp
l2protocol-tunnel stp
l2protocol-tunnel vtp
SWITCH2 port toward ROUTER has configuration:
Interface GigabitEthernet 1/0/2
switchport access vlan 222
When ROUTER connects to SWITCH2
with interface configuration:
Interface GigabitEthernet0/1.10
encapsulation dot1q 10
ip address 10.0.0.1 255.255.255.0
then port on SWITCH1 goes to error disable state:
%PM-4-ERR_DISABLE: l2ptguard error detected on Gi1/0/1, putting Gi1/0/1 in err-disable state.
Everything works only when l2ptprotocol commands are removed either from SWITCH1 or SWITCH2.
Can anyone give me explanation for this behavior.
Thanks in advance,
A
Overall Rating: 5 (1 ratings)
Laurent Aubert Fri, 09/18/2009 - 06:28
Hi Antonio,
It's an expected behavior as switch 1 detects a Loop condition:
from http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_13_ea1/configuration/guide/swtunnel.html#wp1006657
If an encapsulated PDU (with the proprietary destination MAC address) is received from a tunnel port or access port with Layer 2 tunneling enabled, the tunnel port is shut down to prevent loops.
You can't tunnel twice those protocols. It's not supported.
Laurent.
