09-18-2009 07:35 AM - edited 03-07-2019 12:32 AM
we are only seeing the protocols above being reported with nbar on an 877 dialer interface and atm0. Can't figure out why this is happening.
#sh ip nbar prot
Dialer1
Input Output
Protocol Packet Count Packet Count
Byte Count Byte Count
30sec Bit Rate (bps) 30sec Bit Rate (bps)
30sec Max Bit Rate (bps) 30sec Max Bit Rate (bps)
notes 0 26495
0 11073768
0 0
0 195000
rtp 0 252146
0 16641636
0 0
0 52000
http 0 6586
0 2479777
0 0
0 49000
sqlnet 0 275
0 61560
0 0
0 9000
telnet 8375 208
402490 18717
0 0
4000 3000
netbios 0 1045
0 147430
0 0
0 7000
exchange 0 1601
0 269894
0 0
0 5000
Thanks for any input
Kev
09-18-2009 08:02 AM
The reason that you are able to see only some protocols with NBAR is because NBAR is not able to recognize other protocols you may be running and that's because you do not have PDLM's or Packet Description language Modules installed for other Protocols that you should be seeing. These PDLM's help NBAR recognize/classify packets.
Rohit
09-18-2009 08:13 AM
Hi Rohit,
Thanks for replying. The protocols are being recognized outbound ok and its specifically the rtp packets we're interested in to know why they aren't showing inbound to the device.
Kev
09-18-2009 08:32 AM
Kev,
This essentially means that the NBAR is not able to
1)either recognize packets coming in
2)or see packets coming in
But why would'nt it recognize, it should do so, unless there's some bug, which is very unlikely, so moving to the next cause
Do you see packets arriving on the interface, i.e. are those packets actually hitting the interface because i guess some other redundant interface could be receiving packets. Sub-Optimal routing or essentially Asymmetric routing could cause such behavior. So, if you have a redundant path be sure to check it.
Rohit
09-18-2009 09:03 AM
What version of IOS are you running?
09-21-2009 12:29 AM
Morning Lavramov,
We're running c870-advipservicesk9-mz.124-15.T8.bin on the devices we see the lack of inbound nbar information on.
Kev
09-21-2009 11:08 AM
There seems to be some errors on this code.
I tried on c870-advipservicesk9-mz.124-24.T1.bin and it seems to work.
can you try this code?
