ASA in transparent mode with 2 different VLANs but 1 subnet
Sep 18th, 2009
I have a question about ASA in transparent mode. Would it be possible to deploy ASA in transparent mode with 2 different VLANs but only 1 subnet as attached file? I would like to deploy like this because there are 2 core switches and also 2 server farm switches which is full mesh connected. So, it might be better if it is possible to use just 2 ASA instead of 4.
Please let me know if I misunderstood anything.
Nitass
Jon Marshall Fri, 09/18/2009 - 10:08
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Nitass
"Would it be possible to deploy ASA in transparent mode with 2 different VLANs but only 1 subnet as attached file?"
Yes, in fact that is the recommended way to deploy a transparent firewall. You need the same IP subnet because it is a L2 firewall not L3. But you have to use 2 vlans to avoid STP issues ie. if you only used 1 vlan you would get a L2 loop.
Jon
nitass Sat, 09/19/2009 - 03:25
Jon,
Thank you very much but I am so sorry I could not catch you. Have you had a look my diagram? Would you mind explaining me a little bit more?
Nitass
