IOS SLB and SUP2/MSFC2
Sep 18th, 2009
I would like to run SLB on c6500 with sup2/msfc2. I don't have any hardware like CSM or ACE module but I want to use SLB in IOS. I would like to use “directed mode “ but I afraid that it could be a problem with performance. Actually I didn't find any information about
performance in that kind of configuration. How can I calculate ?
thanx in advice .
Rico Nego
Overall Rating: 3.5 (2 ratings)
Laurent Aubert Fri, 09/18/2009 - 14:43
  • Cisco Employee,
Hi Rico,
It's supported. Flows are switch in hw and only the packets used for the initial/tear down session negotiation are punted to the MFSC.
So the limit depends on the number of pps the MFSC can handle which are around 500kpps.
I strongly encourage you to do anyway these performance tests based on your environment to have precise results
Laurent.
rico.nego.rico.nego Sat, 09/19/2009 - 08:06
Hi Laaubert,
thanx, I thought that in " dispatch mode" flows are switch in hw.
Thanks again.
Rico
