opt 150 when you have multiple call manage clusters
Sep 18th, 2009
A switch with one voice vlan and a mixed set of users such as IPT users connected to a IPT cluster and call center users connected to a call center cluster. Having an issue trying to deliver opt 150 to them uniquely. dhcp does not seem to have a mac to option mechanism without reserving an ip address. Any help appreciated
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Fri, 09/18/2009 - 09:32
Seem to me you ought to split the vlan depending on which CM the phone has to go.
Some cisco switches also support mac-based vlans
htluo Fri, 09/18/2009 - 09:35
This is done by "DHCP scope". On DHCP server, you may define different scopes and each scope would have different options.
In the router, you configure ip-helper. Depending on the different forwarding address, DHCP will choose different scope to offer IP addresses.
This is a very standard configuration.
Hope this help.
Paolo Bevilacqua Fri, 09/18/2009 - 09:41
Michael, the thing is that in a single vlan, there will be a single forwarding address so it won't be possible to distinguish on that basis.
Perhaps there is some other attribute that can be used.
htluo Fri, 09/18/2009 - 09:55
Ah...ok, didn't notice that.
Yes, they'll have to separate those into different VLANs.
