09-18-2009 10:52 AM - edited 03-15-2019 07:48 PM
I have a gateway where foll config exist. This gateway has a sip trunk to callmanager where mtp is checked
when i make calls using this sip trunk, calls drop after 15 mins..could this be sip reinvte issue.If yes, how do i fix this issue
any tip appreciated
dial-peer voice 25311 voip
preference 1
destination-pattern 800.......
session protocol sipv2
session target ipv4:172.25.8.11
incoming called-number .
dtmf-relay sip-notify rtp-nte
codec g711ulaw
dial-peer voice 25310 voip
preference 2
destination-pattern 8.........
session target ipv4:172.25.8.10
codec g711ulaw
Solved! Go to Solution.
09-28-2009 07:31 PM
It's almost definitely related to session expiry or refresh. A common value is 1800 (30 minutes) and the refresh happens at half of that.
Likely there is a signaling error or a failure to negotiate the refresh value.
You may also want to change some of the refresh values in CUCM - maybe you can just refresh faster than the other side and avoid the issue altogether.
There were a number of re-invite based bugs in the earlier 20T/22T/24T versions, but as far as I know most of them are fixed in 20.T4
-nick
09-18-2009 11:10 AM
You know, I have the same issue since two years and didn't yet made and effort to fix it.
I just kind of live with that.
09-18-2009 02:35 PM
If you're using SIP with CUCM, you're probably best on a 12.4(20)T or later IOS. The SIP stack was pretty well updated in this release, and you'll see a lot of features like mid-call reinvites working better. If you're doing SIP-SIP make sure you have:
voice service voip
sip
midcall-signalling passthru
hth,
nick
09-28-2009 03:13 PM
Tried adding this, still drops. I should take a trace and didn't yet.
09-28-2009 07:31 PM
-nick
09-28-2009 08:19 PM
Changed the "SIP session-expires" timer to 86400 seconds on the CM service parameters.
and that fixed the issue
