a mac address for a Vlan
Sep 18th, 2009
Could someone please tell me if a mac address is getting created as a result of creating a layer 2 Vlan?
Thanks..
Lucien Avramov Fri, 09/18/2009 - 14:05
Mac address of what? A switch port?
Every switch port has a mac address.
I dont understand your question.
s.ballew Wed, 10/21/2009 - 13:17
No, a MAC address is not created as a result of creating a layer 2 VLAN. A MAC address is a uniquue hadware identifier (expressed in hex format) and is present when a device comes out of the box. Each switch port has a MAC associated with it. Each host also has a MAC associated with it.
nelson.garcia Wed, 10/28/2009 - 08:58
MAC addresses can be mapped to VLANs when using STP with PVST+. PVST+ allows the switch to create an STP instance per VLAN and allows an STP topology PER Vlan, therefore, you'll have one root bridge per VLAN and a MAC address for each root bridge on these VLANs. Can someone correct me if I'm wrong?
Sorry if this isn't the answer you're looking for, I'm new at answering questions. =]
jfraasch Tue, 11/03/2009 - 11:47
Just tested this on a Cisco 3750 on my desk.
I had VLAN 1 Shutdown.
I did a show mac-address-table and there was no MAC for Vlan 1.
I unshut the VLAN 1 interface (no IP configured on it) and now there IS a mac-address entry in my table.
Understand that this is different than just adding say VLAN 10 to your vlan database or something like that.
If all you did was add a VLAN (re, not a virtual interface) to your vlan config then it will NOT create a mac-address entry.
However, if you create an interface, it will.
So the answer to your question is, it depends on what you are trying to do.
Hope that helps!
James
