7921 shows connection failure error
I am using AP 1131, it working [ I am able to associate with laptop ], but in 7921 it show "connection failure error", any suggestion to troubleshoot this problem
migilles
If the laptop works, then could be a config issue on the 7921 or the AP country code is not supported.
What 7921 model do you have?
What authentication/encryption are you using?
What country code is being sent by the AP?
Refer to the 7921G Deployment Guide for the supported country codes.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7921g/6_0/english/deployment/guide/7921dply.pdf
