Problem with routing from LAN to WAN
Answered Question
Sep 18th, 2009
Hello! I'm new to Cisco devices and now have troubles with routing from LAN to internet. My ISP offers PPTP connection via ethernet cable, and I'm trying to setup Cisco 871w (c870-advsecurityk9-mz.124-15.T7.bin). I managed to connect to ISP, so I'm now getting real ip and can ping/trace any remote host from router console. I can also ping router from desktop computers, but I can't ping default gateway or any other host in internet.
Network configuration is pretty simple. Desktops should go into 10.254.254.0 via ethernet or wifi (haven't tried it yet). Dialer17 connects to PPP server : ppp.inetvl.ru (172.16.4.1). Then it receives local ip address: 172.16.67.18, default gateway: 172.16.67.1.
ISP also gave me several static routes, I add them using `ip route`. So here goes `sh ru`:
Router#sh ru
Building configuration...
Current configuration : 2377 bytes
version 12.4
no service pad
service internal
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
no ip gratuitous-arps
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1
ip dhcp pool HOME
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 192.168.1.1
lease infinite
ip multicast-routing
vpdn enable
vpdn-group 22
request-dialin
protocol pptp
rotary-group 17
initiate-to ip 172.16.4.1
username admin privilege 15 secret 5 $1$nHUH$PqLKF4ejczfixqn0/3N5p.
archive
log config
hidekeys
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
mac-address 0023.5a6e.ebb7
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no cdp enable
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
interface Vlan1
ip nat inside
ip tcp adjust-mss 1452
interface Dialer17
mtu 1450
bandwidth 100000
ip address negotiated
ip nat outside
encapsulation ppp
dialer in-band
dialer idle-timeout 0
dialer string 123
dialer vpdn
dialer-group 22
no peer neighbor-route
no cdp enable
ppp pfc local request
ppp pfc remote apply
ppp encrypt mppe auto
ppp chap hostname ***
ppp chap password 0 ***
ppp ipcp dns request
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer17
ip route 95.154.112.64 255.255.255.192 172.16.67.1
ip route 95.154.113.0 255.255.255.128 172.16.67.1
ip route 172.16.0.0 255.240.0.0 172.16.67.1
ip route 192.168.0.0 255.255.0.0 172.16.67.1
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 24 interface Dialer17 overload
access-list 23 permit 0.0.0.0 255.255.255.0
access-list 24 permit 0.0.0.0 255.255.255.0
dialer-list 22 protocol ip permit
no cdp run
control-plane
line con 0
login local
no modem enable
transport preferred telnet
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
...So the problem is that I can only ping 172.16.67.18 from desktop, but I can't reach 172.16.67.1 or any other remote address. How do I share internet from router to other computers in LAN?
Thanks in advance.
Correct Answer by Giuseppe Larosa about 7 years 7 months ago
Hello Nikolai,
if those ISP subnets have to be accessed without natting you need to exclude from translations those communications.
example
ip access-list extended NAT_TRAFFIC
deny ip 192.168.1.0 0.0.0.255 192.168.0.0. 0.0.255.255
deny ip 192.168.1.0 0.0.0.255 172.16.0.0 0.0.255.255
permit ip 192.168.1.0 0.0.0.255 any
in this way traffic for the internet is defined as all traffic not directed to ISP private subnets.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Jon Marshall Sat, 09/19/2009 - 12:00
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Your acl for the NAT doesn't look right. Assuming it is meant to be "permit any" then change to -
access-list 24 permit 0.0.0.0 255.255.255.255
Jon
backdrift Wed, 09/30/2009 - 18:12
Thanks for reply, Jon, I almost got it. Now I have internet both on router and on desktop PCs. But still there's problem - can't access my ISP local resources.
Here's the scheme once again:
1. My Home LAN (fa0/3+wifi via BVI1): 192.168.1.0
2. FastEthernet4: 172.16.67.18 (gateway 172.16.67.1)
3. ISP LAN: 95.154.112.0, 95.154.113.0, 172.16.0.0, 192.168.0.0 (static routes)
4. Internet (PPTP via Dialer)
I made access-list with local IPs and created rule for overloaded NAT:
ip nat inside source list NAT_TRAFFIC interface Dialer17 overload
But in this case I can't access ISP LAN. If I change overloaded interface from Dialer to Fa4 I go into LAN, but Internet disappears) I made a picture just in case: http://yfrog.com/0uciscop
And config once again:
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service internal
dot11 ssid ***
vlan 1
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 0 ***
ip source-route
ip dhcp pool HOME
import all
lease 0 2
ip cef
no ipv6 cef
vpdn enable
vpdn-group 22
request-dialin
protocol pptp
rotary-group 17
bridge irb
mac-address 0023.****.****
ip address 172.16.67.18 255.255.255.0
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
duplex auto
speed auto
ntp broadcast client
no cdp enable
interface Virtual-Template1
mtu 1476
no ip address
no ip address
encryption mode ciphers tkip
encryption vlan 1 mode ciphers tkip
broadcast-key change 3600
ssid ***
54.0
station-role root
l2-filter bridge-group-acl
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 port-protected
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip flow ingress
ip nat inside
load-interval 30
fair-queue
bridge-group 1
interface Dialer17
mtu 1476
bandwidth 100000
ip nat outside
encapsulation ppp
dialer in-band
dialer string 123
dialer vpdn
dialer-group 22
no cdp enable
interface BVI1
ip nat inside
ip default-gateway 172.16.67.1
ip dns server
ip dns spoofing
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
Correct Answer
Giuseppe Larosa Thu, 10/01/2009 - 08:48
  • Hall of Fame,
    Founding Member
Hello Nikolai,
example
Hope to help
Giuseppe
backdrift Wed, 10/07/2009 - 18:52
Thank's, giuslar. It works this way:
ip nat inside source list NAT_INTERNET interface Dialer17 overload
ip nat inside source list NAT_ISP interface FastEthernet4 overload
ip access-list extended NAT_INTERNET
deny ip 192.168.1.0 0.0.0.255 95.154.112.0 0.0.0.255
deny ip 192.168.1.0 0.0.0.255 95.154.113.0 0.0.0.255
deny ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.255.255
ip access-list extended NAT_ISP
remark From home LAN to ISP LAN
