Recording step is overwriting
Sep 19th, 2009
I appreciate if someone can helpme:I have a recording step then i use de option write document in order to save it. But, if i have two simultaneos calls to the same trigger ( and the caller press de same menu option) both recording (message calllers) mix each other. ¿how to make for leaving a message one at time. I mean, if i have a second call incoming, just disconnected, for instance.
I'm doing de test in uccx 4.5(2)Ipcc express Enhanced.
thanks any way...
Overall Rating: 4 (1 ratings)
villarrealed Wed, 09/23/2009 - 11:29
  • Bronze, 100 points or more
You will need to have the file saved with a unique name otherwise it will overwrite the previous recording. You could append the current date & time to the filename to make it uniqueue for example.
floresj Sun, 09/27/2009 - 10:19
Thanks for the advice I'm still working on it, and trying to figure out. I'll let you know if i could make it.
thanks.
