Convert any Cisco IP Phone from sccp to sip???
Answered Question
Sep 19th, 2009
If 7960, 7961 and 7965 with sccp image.
I found a doc at cisco website about convert sccp to sip for 7940/7060.
I guess my question is that can this step apply to 7961 and 7965 or the rest of 79xx series model???
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a0080094584.shtml
I found other website that show up how to convert sccp to sip also:
http://www.3cx.com/support/convert-cisco.html
Correct Answer by paolo bevilacqua about 7 years 8 months ago
In short, yes.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Sat, 09/19/2009 - 15:45
  • Hall of Fame,
    Founding Member
In short, yes.
requiem1114 Sat, 09/19/2009 - 20:44
p.bevilacqua.
Can I use those phones for 3rd party SIP call control environment after convert??
I saw 7940/60 has 3rd party firmware from cisco download website. But I dont see 3rd party firmware for 7961 or 7965.
paolo bevilacqua Sun, 09/20/2009 - 02:29
  • Hall of Fame,
    Founding Member
I think using cisco phones with 3party is a bad idea. You end up with many problems and do not use the many features of the phone. For example SIP loads do not support localization. Moreover I cannot get the 7941 phone to work with 3CX currently, and I'm ready to drop the ball.
If you want a simple and economic solution, use CCME on any router. It does a lot more than the "low cost solutions", is more stable, better documented and constantly evolving.
paolo bevilacqua Sun, 09/20/2009 - 12:37
  • Hall of Fame,
    Founding Member
Virtual PBX hosted solutions all have issues, go ahead and try. BTW cisco phones don't support STUN so working with NAT is a nightmare.
You will find that $600 for a 2801 is very well spent money for a full-featured and robust PBX.
CUE is not mandatory.
paolo bevilacqua Mon, 09/21/2009 - 00:26
  • Hall of Fame,
    Founding Member
Yes you need CUE for voice mail.
What I've found is that in this world of email, SMS and cellphones, many customers do happily without vmail. At least in EU.
