Catos to ios urgent help
Sep 19th, 2009
gusy we have couple of 6500 swicthes and its running catos and ios as well but now we have to only put IOS on it and take out catos....guys i have took a screen shot please have a look an dtell me how to do that (takeout catos and put ios) as i have never don eit guys its core swicthes so kindly it would be nice if someone tell me step by step....secondly can some one tell th elatest and stable IOS version which support BGP so that we can purchase it from cisco thanks heaps plz look at below to see what we have in 6500 as i dont even know what these modules are thanks
(enable) sh module
Mod Slot Ports Module-Type Model Sub Status
1 1 2 1000BaseX Supervisor WS-X6K-S2U-MSFC2 yes ok
15 1 1 Multilayer Switch Feature WS-F6K-MSFC2 no ok
2 2 2 1000BaseX Supervisor WS-X6K-S2U-MSFC2 yes standby
16 2 1 Multilayer Switch Feature WS-F6K-MSFC2 no ok
3 3 8 1000BaseX Ethernet WS-X6408A-GBIC no ok
4 4 48 10/100/1000BaseT Ethernet WS-X6148-GE-TX no ok
5 5 48 10/100BaseTX Ethernet WS-X6348-RJ-45 no ok
Overall Rating: 5 (2 ratings)
Leo Laohoo Sat, 09/19/2009 - 20:28
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
I'm not sure about the others but no one will recommend you a specific version even if you provide information or not.
Go to the Cisco Feature Navigator (http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp) and make your selection. Cisco Bug Toolkit is also another.
Regarding the stability, go through the release document and verify if the bugs identified will, in any shape or size, affect your network.
System Software Conversion from CatOS to Cisco IOS for Catalyst 6500/6000 Switches
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015bfa6.shtml
System Software Conversion from Cisco IOS to CatOS for Catalyst 6500/6000 Switches
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801350b8.shtml
How to Convert a Catalyst 6500/6000 Supervisor Engine from Hybrid Mode (CatOS) to Native Mode (IOS) Using a Conversion Utility
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008070f124.shtml
Hope this helps.
The_guroo_2 Sat, 09/19/2009 - 23:26
Thanks for that now we have SUP2-2GE and MSFC2 card.....now if i have to download just IOS do ihave to keep in consideration that it shd be support by both or just go to IOS navigation and download an IOS which is for MSFC2??????
Giuseppe Larosa Sun, 09/20/2009 - 00:49
  • Hall of Fame,
    Founding Member
Hello Khan,
moving to IOS native mode means a single IOS image for both the MSFC2 and the SUP2.
the native IOS images have a name convention that is explained in the documents that Leo has provided
in your case the IOS image name should start with
c6sup22*.bin
that means sup2 and MSFC2
follow the conversion procedures step by step.
Hope to help
Giuseppe
The_guroo_2 Sun, 09/20/2009 - 05:03
hi i went to IOS navigation and there for 6000 i could only get the follwoing its says MSFC2
c6msfc2-adventerprisek9_wan-mz.122-18.SXF16.bin
so doe sit mean it would not be supported??? thanks
The_guroo_2 Sun, 09/20/2009 - 05:09
sorry for th elast reply i meant to say i saw sup2/msfc2 and chose the follwoing
s222-adventerprisek9_wan-mz.122-18.SXF16.bin
it doesnt start with c as u have mentioned is it right or wrong??? as we have to put an order shortly
Giuseppe Larosa Sun, 09/20/2009 - 10:29
  • Hall of Fame,
    Founding Member
Hello Khan,
that's correct latest releases use the prefix s222 I hadn't find a C6500 with sup2/MSFC2 in my net so I tried to use my memory that can fail.
this should be fine
Hope to help
Giuseppe
The_guroo_2 Tue, 09/22/2009 - 07:52
Thanks Giuseppe
Now one last question which i am still confuse about......currently sup has catos and MSFC has a IOS....now the ios i have choose requirment is 256/64
so i beleive 256 is dram and 64 is bootflash or flash i guess.....now i ahve to buy a PCMCIA card now what abt dram shd it be upgarded on supervisor module or MSFC??? thanks dude
