Cisco Firewall Product Line
Sep 20th, 2009
  • Blue, 1500 points or more
Hi:
I am looking for a firewall solution that can provide 5-Gbps of IPSec 3DES traffic processing.
The highest of the ASA product line (5580) can handle a maximum of 1-Gbps. I think the reason for this is that, in Cisco's view, the ASA is an enterprise-level appliance. That is also probably why it only supports AC power.
What product line should service providers look for to provide at least 5-Gbps of 3DES traffic and DC power support?
Victor
Overall Rating: 5 (3 ratings)
Lucien Avramov Sun, 09/20/2009 - 00:51
  • Red, 2250 points or more
The FWSM module in CAT6k provides you 5.5 GBPS:
http://www.cisco.com/en/US/prod/collateral/modules/ps2706/ps4452/product_data_sheet0900aecd803e69c3.html
CAT6k can run of AC or DC or mixed powers:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfa8.shtml#power_red
ASA 5540 is Up to 1.2 Gbps throughput and BTW there is a DC power supply for ASA, not sure what you are referring to that says it does not. The part number is: ASA-180W-PWR-DC
lamav Sun, 09/20/2009 - 00:56
Hi:
Thanks.
The FWSM supports up to 5.5 Gbps of clear text, not IPSec. I dont see the IPSec spec on that data sheet.
Would have to check out the DC power thing. It was a Cisco SE who told me the ASA doesnt support DC.
Lucien Avramov Sun, 09/20/2009 - 01:12
Give to the SE the part number for the DC power ;)
ASA-180W-PWR-DC
Giuseppe Larosa Sun, 09/20/2009 - 00:57
  • Hall of Fame,
    Founding Member
Hello Victor,
we have recently installed a pair of ASA 5580-40 that have 10Ge interfaces and should be able to process 5 Gbps of traffic.
see
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/product_data_sheet0900aecd802930c5.html
We had a major issue with a bug but it has been solved.
Our experience with FWSM is that they don't support really 5 Gbps so we have used failover groups putting different contexts in different failover groups and making FSWM1 active for group1 and FWSM2 active for group2
( a FWSM pair on two C6500 chassis)
Hope to help
Giuseppe
lamav Sun, 09/20/2009 - 01:03
Hi, Giueseppe:
The 10G specification is for clear text throughput. The spec right below that shows Max VPN throughput. Its 1Gbps.
lamav Sun, 09/20/2009 - 01:13
You mentioned the FWSM and that it supports 5 Gbps. Thats clear text, not IPSec. Im asking about IPSec throughput.
[Edit] Now that you edited your response to include the VPNSM, I will edit mine to say that I will look that up. [EDIT] :-)
Lucien Avramov Sun, 09/20/2009 - 01:15
Check my answer: I refer you to the VPNSM module for the IPSEC portion:
Check out the VPNSM blade that can be added to the FWSM:
http://www.cisco.com/en/US/products/hw/modules/ps2706/ps4221/index.html
The solution you are looking for could be met with a couple of VPNSM modules.
It's very unusual to look for such high rates of IPSEC traffic. Maybe the design should be reviewed and split into a couple of devices.
lamav Sun, 09/20/2009 - 01:18
The problem is that the client runs a Juniper shop, and the Juniper srx-3400 supports up to 10Gbps of IPSec. So a Cisco solution would have to support at least half of that, according to client specs.
Lucien Avramov Sun, 09/20/2009 - 01:23
For now we support up to 8-80 Gbps on a cat6k switch. Check out that last doc I referred where there is also the ASR1k.
80 GBPS will be with a chassis fully loaded of vpn modules, but technically it's achievable. That will be 8 times that juniper device.
It will boil down to cost, and design. The solution exists.
Giuseppe Larosa Sun, 09/20/2009 - 01:25
  • Hall of Fame,
    Founding Member
hello Victor,
sorry I overlooked the table.
if the device has to act as IPSec VPN concentrator you could consider ASR 1006 with ESP 20
a pair of devices should be able to deliver 5 Gbps ipsec each,
see
http://www.cisco.com/en/US/partner/prod/collateral/routers/ps9343/data_sheet_c78-450070.html
Of course VPNSM suggested by Lucien can be attractive if you deploy two C6500 boxes and you need other services / service modules.
Hope to help
Giuseppe
lamav Sun, 09/20/2009 - 05:07
Thanks, G:
Lucien Avramov Sun, 09/20/2009 - 01:19
Also, here is a complete list of our solutions.
May be the ASR 1k could be the answer in your scenario: 7 GBps of throughput.
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6635/ps7180/prod_brochure09186a00801f0a72_ns710_Networking_Solutions_Brochure.html
Hope this resolves your questions. Good luck choosing the product meeting your requirements.
lamav Sun, 09/20/2009 - 01:21
Thank you, sir.
