Equivalent to "sh isdn ac" when using MGCP
Sep 20th, 2009
  • Blue, 1500 points or more
When a voice gateway is in MGCP mode, "sh isdn ac" doesn't work.
Is there a way to get similar information ?
The closest I've come up with is "sh voice port sum" (Which isn't great)
GTG
Paolo Bevilacqua Sun, 09/20/2009 - 03:00
  • Hall of Fame,
    Founding Member
With MGCP, call-control intelligence is taken away from the router, so its ability to tell you what's going on will become very limited.
So, either use H.323, or look into the CUCME for any kind of monitoring and statistics information.
Nicholas Matthews Sun, 09/20/2009 - 17:04
  • Red, 2250 points or more
'show call active voice brief' can be helpful, but when the ISDN b-channel is back-hauled to CUCM there is no way for the gateway to know the ISDN details. So the gateway will know which ports are in use, but no calling/called numbers.
-nick
