Connecting a Cisco 3640 FXO Voice port (VIC-2FXO) to the SPA9000
Sep 20th, 2009
I am wanting to use my existing FXO ports on my 3640 router (VIC-2FXO) as my PSTN connections to my new SPA9000.  Do you have the best suggestion/config that would allow me to do this? Thanks for your time.
Patrick Born Mon, 09/21/2009 - 14:55
  • Cisco Employee,
Hi james-richter,
You're in uncharted and unsupported territories....  :-)
I don't know anything about the Cisco 3640, but if you can get its FXO ports to register to the SPA9000, you should be able to get it to work.
Run the SPA9000 in debug level 3 mode and run the related SPA9000 line in Full debug mode so you will have an idea of what is going on:
https://www.myciscocommunity.com/docs/DOC-3032
The SPA9000 web-ui Admin Guide should prove useful in your quest:
SPA9000 web-ui: http://www.cisco.com/en/US/docs/voice_ip_comm/csbpvs/spa9000/installation/guide/spa9000_voice_system_webui_ig.pdf
Good luck,
Patrick
