6506 Supervisor 720 Problem
Sep 20th, 2009
I'm trying to determine the problem of our 6500 switch. One is using Sup720 and the other one is Sup720-3bxl. They are using the same IOS image. That's not an issue right? As there is no specific image only for Sup720 and Sup720-3bxl. Correct me if I'm wrong.
Next, I don't know what's wrong with the show logging output. The switch rebooted unexpectedly and we are in doubt that this might happen again. Please see logs below and please let me know if there's something interesting. If it's a hardware or software issue.
00:01:03: curr is 0x20000
00:01:03: RP: Currently running ROMMON from F2 region
00:01:27: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
00:01:30: %SYS-5-CONFIG_I: Configured from memory by console
00:01:32: %SYS-5-RESTART: System restarted --
IOS (tm) s72033_rp Software (s72033_rp-PSV-M), Version 12.2(18)SXD7b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Fri 08-Dec-06 12:38 by ccai
00:01:32: %SYS-6-BOOTTIME: Time taken to reboot after reload = 1617643 seconds
00:00:12: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
00:00:13: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
Firmware compiled 24-Oct-06 16:18 by integ Build [100]
- RELIABILITY DRIVER: wrong signature on NVFLASH
00:01:23: SP: SP: Currently running ROMMON from F2 region
00:01:27: %SPANTREE-SP-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
00:01:29: %C6K_PROCMIB-SP-3-IPC_PORTOPEN_FAIL: Failed to open port while connecting to process statistics: error code = no such port
-Traceback= 4087F6D8 4087F810
00:01:32: %C6K_PROCMIB-SP-3-IPC_PORTOPEN_FAIL: Failed to open port while connecting to process statistics: error code = no such port
-Traceback= 4087F6D8 4087F830
00:01:32: %SYS-SP-5-RESTART: System restarted --
IOS (tm) s72033_sp Software (s72033_sp-PSV-M), Version 12.2(18)SXD7b, RELEASE SOFTWARE (fc1)
Compiled Fri 08-Dec-06 12:31 by ccai
00:01:34: %OIR-SP-6-INSPS: Power supply inserted in slot 1
00:01:34: %C6KPWR-SP-4-PSOK: power supply 1 turned on.
00:01:34: %OIR-SP-6-INSPS: Power supply inserted in slot 2
00:01:34: %MLSM-6-MMLS_MODE_CHANGE: MMLS: Replication Mode Change Detected because oir event
00:01:34: %C6KPWR-SP-4-PSOK: power supply 2 turned on.
00:01:34: %C6KPWR-SP-4-PSREDUNDANTBOTHSUPPLY: in power-redundancy mode, system is operating on both power supplies.
00:01:36: %C6KENV-SP-4-FANHIOUTPUT: Version 2 high-output fan-tray is in effect
00:01:39: %FABRIC-SP-5-CLEAR_BLOCK: Clear block option is off for the fabric in slot 5.
00:01:40: %FABRIC-SP-5-FABRIC_MODULE_ACTIVE: The Switch Fabric Module in slot 5 became active.
00:01:41: %DIAG-SP-6-RUN_MINIMUM: Module 5: Running Minimum Diagnostics...
00:01:53: %DIAG-SP-6-DIAG_OK: Module 5: Passed Online Diagnostics
00:01:54: %OIR-SP-6-INSCARD: Card inserted in slot 5, interfaces are now online
00:01:57: %DIAG-SP-6-RUN_MINIMUM: Module 3: Running Minimum Diagnostics...
00:01:58: %DIAG-SP-6-RUN_MINIMUM: Module 2: Running Minimum Diagnostics...
00:02:02: %MLSM-6-MMLS_MODE_CHANGE: MMLS: Replication Mode Change Detected because oir event
Thanks in advance.
John
Overall Rating: 0 (1 ratings)
Giuseppe Larosa Sun, 09/20/2009 - 15:33
  • Hall of Fame,
    Founding Member
Hello John,
the lines you have posted show the reboot but not the reason for reboot.
you can use
sh ver
sh stack
and you can check with dir /all if there is a crashinfo file for the reload.
these can provide more useful information
Edit:
only interesting lines are :
00:01:29: ÆK_PROCMIB-SP-3-IPC_PORTOPEN_FAIL: Failed to open port while connecting to process statistics: error code = no such port
but these can be during the reboot not the cause of it.
Hope to help
Giuseppe
John Patrick Lopez Sun, 09/20/2009 - 16:57
I rebooted the switch with the reload command but the reason for the reload was different in show version and show stack.
sh stack
Minimum process stacks:
Free/Size Name
5704/6000 OIR IOS Process
5536/6000 IPC Zone Manager
5688/6000 ICC Retry Q
4544/6000 IPC delayed init
4888/6000 IPC delayed funcs
5704/6000 CDP BLOB
5648/6000 FM HA Sync
5656/6000 L3 Manager HA
5616/6000 Draco FIB process
5616/6000 QM OIR Proc
3528/6000 eobc_init_process
5232/6000 ICC Slave Comp. Up
5592/6000 PM MP Process
1936/3000 EARL INFO CAPABILITY process
5400/6000 C6K ENV RP init
5048/6000 SPAN Subsystem
11496/12000 Router Init
7920/12000 Init
8704/9000 cdp init process
5112/6000 Draco DFS Port Registation Proc
5408/6000 RADIUS INITCONFIG
Free/Size Name
5016/6000 LCC Configure
4032/6000 draco-oir-process:slot 5
2328/3000 L3 MGR Send ARP Req
4584/6000 SLB RF Active Proc
4240/6000 draco-oir-process:slot 3
5240/6000 CEF Reloader
4240/6000 draco-oir-process:slot 2
5600/6000 BGP Accepter
4928/6000 BGP Open
8296/12000 Exec
5560/6000 Link Status process
34936/36000 TCP Command
19616/24000 show techsupport huge_stack
8264/12000 Virtual Exec
Interrupt level stacks:
Level Called Unused/Size Name
1 2257087 7664/9000 Inband Interrupt
2 4042541 7560/9000 EOBC Interrupt
3 55932 8456/9000 Management Interrupt
4 73879 8600/9000 Console Uart
5 0 9000/9000 Mistral Error Interrupt
7 13981851 8584/9000 NMI Interrupt Handler
Spurious interrupts: 229
System was restarted by bus error at PC 0x41D8590C, address 0x0 at 12:48:04 UTC Wed Feb 2 2000
Compiled Fri 08-Dec-06 12:38 by ccai (current version)
Image text-base: 0x4002100C, data-base: 0x42040000
Stack trace from system failure:
FP: 0x5000BB28, RA: 0x41D8590C
FP: 0x5000BB28, RA: 0x41D83858
FP: 0x5000BB48, RA: 0x41B32454
FP: 0x5000BB60, RA: 0x41B32480
FP: 0x5000BB78, RA: 0x41A050D8
FP: 0x5000BBB0, RA: 0x41A46324
FP: 0x5000BBD0, RA: 0x41A3C6BC
FP: 0x5000BBF0, RA: 0x41A3C714
******* Information of Last System Crash **********
Using bootflash:crashinfo_20000112-140324.
%Error opening bootflash:crashinfo_20000112-140324 (File not found)
****** Information of Last System Crash - SP ******
Using sup-bootflash:crashinfo_20000217-140158.
%Error opening sup-bootflash:crashinfo_20000217-140158 (File not found)
xxxxxxxx-6500-standby#sh version
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-PSV-M), Version 12.2(18)SXD7b, RELEASE SOFTWARE (fc1)
xxxxxxxx-6500-standby uptime is 15 hours, 33 minutes
Time since xxxxxxxx-6500-standby switched to active is 15 hours, 32 minutes
System returned to ROM by bus error at PC 0x41D8590C, address 0x0 at 12:48:04 UTC Wed Feb 2 2000 (SP by reload)
System restarted at 05:22:12 edt Sun Sep 20 2009
System image file is "sup-bootflash:s72033-psv-mz.122-18.SXD7b.bin"
cisco WS-C6506 (R7000) processor (revision 2.0) with 983008K/65536K bytes of memory.
Processor board ID TBA04171663
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
X.25 software, Version 3.0.0.
Bridging software.
9 Virtual Ethernet/IEEE 802.3 interface(s)
26 Gigabit Ethernet/IEEE 802.3 interface(s)
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Leo Laohoo Sun, 09/20/2009 - 19:46
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
What is the system clock of your switch? According to your post, the last crashinfo file was made on December 2000.
Giuseppe Larosa Mon, 09/21/2009 - 01:32
  • Hall of Fame,
    Founding Member
Hello John,
there was a bus error at program counter position 0x41D8590C
the IOS image is of December 2006.
the crash declared to be happened in Feb 2000.
Use the following document to go on with the analysis of crash
http://www.cisco.com/en/US/partner/products/hw/switches/ps708/products_tech_note09186a008072c406.shtml
or
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008072c406.shtml
Hope to help
Giuseppe
