09-20-2009 04:27 PM
I'm finding out VPN bandwidth calculator or any formula to calculate bandwidth related to remote VPN.
Let's say, 250 simultaneous/concurrent users connection. What is typical average per conn I think? including voice traffic as well?
How much BW i need to put in my head-end at central site to support for that number of simultaneous users...
Thanks in advance,
Gerard
09-21-2009 02:36 AM
Gerard,
The voice par of your question is easy see the below link:-
http://tools.cisco.com/Support/VBC/do/CodecCalc1.do
However for the rest of your question, only you can answer. You need to find out what applications are used, and their associated bw requirements per user.
HTH>
09-21-2009 03:34 AM
Perfect... this is what i need. Voice is more important than data. Pretty much are 80,443 traffics.
