Logging buffer sizes on ACE 4710
Answered Question
Sep 21st, 2009
We are using Cisco ACE 4710 with the Admin and one other context defined.
We are both logging to syslog servers and to the local buffer for both contexts.
Currently only a few lines are logged in the Admin context buffer. When I issue a show logging command I get the following output:
ACE1/Admin# show logging
Syslog logging: enabled
Facility: 23
History logging: enabled (level- warnings)
Trap logging: enabled (level - information)
Timestamp logging: enabled
Fastpath logging: disabled
Persist logging: disabled
Standby logging: disabled
Rate-limit logging: disabled (min - 0 max 100000 msgs/sec)
Console logging: enabled (level - critical)
Monitor logging: enabled (level - warnings)
Logging to x.x.x.x udp/514
Device ID: hostname "ACE1"
Message logging:
Buffered logging: enabled (level - information) maximum size 4096
Buffer info: current size - 4096 global pool - 1048576 used pool - 1048576
min - 0 max - 4096
cur ptr = 2202 wrapped - yes
If I issue the same command in the other context I get the following information:
ACE1/CONTEXT# show logging
Facility: 23
Message logging:
Buffered logging: enabled (level - information) maximum size 1044480
Buffer info: current size - 1044480 global pool - 1048576 used pool - 1048576
min - 0 max - 1044480
cur ptr = 73251 wrapped - yes
It seems like the log buffer for the Admin context is only 4096 bytes and in the other context it is 1044480 bytes. Is there a way to specify the buffer size for the different contexts?
Thanks in advance for your help!
Best regards,
Harry
Correct Answer by Gilles Dufour about 7 years 5 months ago
Harry,
the logging buffer is a resource.
Like all other resources, you can allocate a min and a max.
switch/Admin(config-resource)# limit-resource buffer syslog ?
minimum Set minimum limit
Gilles.
Overall Rating: 5 (1 ratings)
Correct Answer
Gilles Dufour Mon, 09/21/2009 - 03:01
Harry,
Gilles.
