Unable to get connectivity to ACE
Sep 21st, 2009
i am trying to get ip connectivity to my ace-module from the 6509.
In the switch i enter;
svclc multiple-vlan-interfaces
svclc switch 1 module 3 vlan-group 1
svclc vlan-group 1 505
There is an ip-adress on vlan 505 in the 6509. In the admin context of the ACE-module there is a vlan 505 up and running. Why can i not ping between the modules?
The sh arp in the ace displays;
IP ADDRESS MAC-ADDRESS Interface Type Encap NextArp(s) Status
10.x.x.x 00.00.00.00.00.00 vlan505 GATEWAY - * 2 req dn
dario.didio Mon, 09/21/2009 - 05:15
  • Silver, 250 points or more
you need to allow this.
Add following class, policy map and ACL.
class-map type management match-any REMOTE_ACCESS-CM
description Match management traffic
2 match protocol telnet any
3 match protocol ssh any
4 match protocol https any
5 match protocol icmp any
policy-map type management first-match REMOTE_ACCESS-PM
class REMOTE_ACCESS-CM
permit
access-list all permit ip any any
int vlan 505
access-group input all
service-policy input mgmt
no shut
HTH,
Dario
martensa Mon, 09/21/2009 - 05:53
it doesn't make any difference;
Still unable to ping..
Heres the config..
access-list all line 1 extended permit ip any any
permit
interface vlan 505
ip address x.x.x.x
service-policy input REMOTE_ACCESS-PM
no shutdown
dario.didio Mon, 09/21/2009 - 23:31
Can you post the output for
show int vlan 505
sh arp
are you running ACE on a C6500 VSS pair?
Tnx,
Dario
martensa Mon, 09/21/2009 - 23:45
I assume you ment from the ACE, here it is..
sh int vlan 505
vlan505 is up
Hardware type is VLAN
MAC address is 00:1f:ca:7b:7d:e3
Mode : routed
IP address is 10.x.x.x netmask is 255.255.255.0
FT status is non-redundant
Description:not set
MTU: 1500 bytes
Last cleared: never
Alias IP address not set
Peer IP address not set
Assigned from the Supervisor, up on Supervisor
82 unicast packets input, 2916134 bytes
42798 multicast, 4 broadcast
0 input errors, 0 unknown, 0 ignored, 0 unicast RPF drops
4 unicast packets output, 5696 bytes
0 multicast, 85 broadcast
0 output errors, 0 ignored
sh arp
Context Admin
10.x.x.2 00.00.00.00.00.00 vlan505 LEARNED - * 2 req dn
10.x.x.10 00.1f.ca.7b.7d.e3 vlan505 INTERFACE LOCAL _ up
Total arp entries 2
Yes, ACE is located in a 6500 VSS-pair.
/Andreas
