Jon Marshall Mon, 09/21/2009 - 04:58
Yes the 1841 does support HSRP. Do you have 2 1841 routers as you cannot configure HSRP with 2 interfaces on the same router.
Jon
shridhar_sdl Mon, 09/21/2009 - 20:42
Hi ,
Thanks!! i have two routers 1841. can you let me know one more thing Jon , i have two 1841 router but one routers serail module is spoild totally , till now can i use those routers in HSRP using FE ports.
sourabh1000_2 Mon, 09/21/2009 - 19:46
hi,
primary router
interface fa0/1
desc ****LAN****
ip add 192.168.1.1 255.255.255.0
standby 1 ip 192.168.1.2 (DG of PCs)
standby 1 preempt
standby 1 track 1 (if used wan interface as ethernet)
standby router
interface fa0/1
desc ****LAN*****
ip add 192.168.1.3 255.255.255.0
standby 1 preempt
standby 1 priority 95 (Default is 100 for primary router)
hope u may get idea of the config
shridhar_sdl Mon, 09/21/2009 - 20:44
Which version of IOS it needed and one more thing if i want to upgrade my IOS for basic functionality then what are the charges will taken by Cisco or its free.
sourabh1000_2 Mon, 09/21/2009 - 20:55
hi,
we are using adv.ent or sp.serv IOS for our client
and charges or fees i do not have any ideas..
