ASA 5520 running ver 8.0(2) suddenly stops allocating address to VPN client
hi,
I have been noticing this issue of the ASA not able to assign ip address to the RA VPN clients from its local pool. The same config used to work without any issues but suddenly it has stopped working. Earlier also I faced the same issue but got it resolved by using a separate /24 subnet for the address pool as sometimes VLSM creates problems with the vpn address pool. Below is the config which used to work fine and still running. Can someone pls help urgently, it has become a show stopper. Is there any bug related to this.
object-group network RA_VPN_ADD_POOL
network-object 172.16.20.0 255.255.255.0
ip local pool CogVpnPool 172.16.20.1-172.16.20.254 mask 255.255.255.0
crypto ipsec transform-set CogVPNSet esp-aes-256 esp-sha-hmac
crypto dynamic-map RAVPNMAP 1 set pfs
crypto dynamic-map RAVPNMAP 1 set transform-set CogVPNSet
crypto map vpnmap 1 ipsec-isakmp dynamic RAVPNMAP
crypto map vpnmap interface public
crypto isakmp enable public
crypto isakmp policy 1
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
no crypto isakmp nat-traversal
no vpn-addr-assign aaa
no vpn-addr-assign dhcp
vpn-addr-assign local
group-policy CogVpnUsers internal
group-policy CogVpnUsers attributes
banner value ************************
dns-server value ************
vpn-tunnel-protocol IPSec
default-domain value *********.com
address-pools value CogVpnPool
tunnel-group CogVpnUsers type remote-access
tunnel-group CogVpnUsers general-attributes
authentication-server-group LDAP_SRV_GRP
default-group-policy CogVpnUsers
tunnel-group CogVpnUsers ipsec-attributes
pre-shared-key *
