Connection Recorded Name Replication
Sep 21st, 2009
I have two Connection systems on 7.1.2ES16 that are using digital networking. I have noticed that Connection is using the text to speech translation of subscribers display name as opposed to the subscribers recorded name to announce the sender of a received message or when the system is verifying a address for a composed message to be sent when the subscriber is on the other Connection system. It appears that replication of Recorded name is not working?
Steve
Rob Huffman Mon, 09/21/2009 - 06:24
Hi Steve,
It sounds like this bug that was identified by Unity Guru Lindborg;
CSCta86538 Bug Details
Unity Connection plays tts instead of voice name
Symptom:
UC 7.1.2 plays the tts name from the subscriber's profile instead of playing the recorded voice name. This occus when using the directory handler.
Conditions:
Using the directory handler you can choose a subscriber on the unity system. When you match a subscriber the system will typically play the recorded voice name. In uc 7.1.2 the system plays the tts name.
This is fixed in Connection 7.1(2)ES12 and 7.1(3) and later.
Workaround:
NONE Status
Fixed
Severity
3 - moderate
Last Modified
In Last 2 weeks
Product
Cisco Unity Connection
Technology
1st Found-In
7.1(2)ES1
Fixed-In
8.0(0.163)
7.1(3.49)
7.1(2)ES12
7.1(2.22008.1)
Hope this helps!
Rob
s.casper_2 Mon, 09/21/2009 - 06:31
Close but it works fine when I recieve a message or send a message when the subscriber is on your "home" Connection system. TTS only kicks in when going cross box.
Steve
