IDS alarm feed inactive
Sep 21st, 2009
I am in the middle of a migration to ASA from Pix. I have an old IDS 4215 active the Pix side that now shows feed inactive from sensor. Alarm context is >> certificate expired for cisco secure ids event subscriber notafter Wed Sept 09 2009. Is there a workaround for this? I need to maintain this IDS until the IPS is online. Can I tell java to ignore this?
marcabal Mon, 09/21/2009 - 06:58
The TLS certificate on the sensor has expired. You just need to generate a new certificate on the sensor.
Use the "tls generate-key" command on the sensor to generate a new certificate:
You will then just have to update your management station to use the new sensor certificate.
If you need help with that just let me know what management software you are using and what version.
