How do i check accounting once its enabled?
Sep 21st, 2009
How do i check to see user activity once its enabled on my ASA? I need help setting up the AAA on a radius server as well in regards to where i set up the server secret key?
Help!
Jagdeep Gambhir Mon, 09/21/2009 - 08:53
  • Red, 2250 points or more
Hi Himg,
What type of activity you are looking for ? If you are looking Command accounting, then that is a feature of tacacs server and not radius.
This link with help you with setting up radius authentication.
http://cisco.com/en/US/products/ps6120/products_configuration_example09186a00808c18ff.shtml
Let me know if you have any question.
~JG
Do rate helpful posts
cisco_himg Mon, 09/21/2009 - 09:01
Maybe i can go about this another way...
What about this....
I basically want to know when a user logs off and back on WEBVPN. I really dont want to associate to a Radius nor a TACACS. I want to keep all the users to authenticate locally on the ASA. What all do i need to do?
THanks a bunch!
Jatin Katyal Mon, 09/21/2009 - 09:55
  • Cisco Employee,
radius accounting files contain the following info:
User session's start and stop time frame
AAA client message with username
callier line identification info
session duration
In order to configure this for webvpn user, you need to add this command under webvpn default tunnel group
accounting-server-group
In oder to check share sceret key for any aaa client. Go to network configuration > NDG (if any) > aaa client edit > look for shared secret key.
JK
cisco_himg Mon, 09/21/2009 - 10:19
if i add the shared secret key on the ASA, where do i add the same key on the radius server?
cisco_himg Mon, 09/21/2009 - 10:49
thank you..
i have never downloaded the ACS before..which one do i download?
