09-21-2009 08:05 AM - edited 03-15-2019 07:49 PM
I have a fairly customized requirement to setup AA on Unity 5.0. Most of the rules end up routing to a specific extension. Currently Unity is setup for VM only.
Any configuration examples or things to look out for would be appreciated such as what if a invalid key is selected?
thanks in advance
Ajaz
09-22-2009 06:52 AM
An AA are just call handlers and caller input settings so there is nothing difficult on creating one
Unity Voicemail: Repeat the Same Greeting when an Invalid Key is Pressed
java
if this helps, please rate
09-22-2009 06:58 AM
Hi Java (nice name :)
any info on switching to night service etc, and how/where to allow a user to do this?
-Ajaz
09-22-2009 07:06 AM
That is the same as with any subscriber, configure the schedule and std/closed greetings so they activate as needed.
java
09-22-2009 07:59 AM
Java,
ok that's fine - I have another qtn. In terms of routing the call to unity and unity to recognize that a call handler must be initiated, what is the order and configuration tasks to be completed?
As i've stated - currently the setup is default for vm only. CTI route points have been configured for this and there are a total of 96ports. I need to be sure that any changes which I make do not impact the vm functionality as this is a production system :)
tia
Ajaz
09-22-2009 08:07 AM
A) Configure CTI RP with CFA and define the call handler using that DN
B) Same as above but use routing rules instead of DN
java
09-22-2009 08:24 AM
Java
Apologies but I didn't quite get what you meant here:
Are there any config guides which can be used to perform the required tasks?
thanks dude
Ajaz
