Mobile Connect CUCM 6.1.3
Sep 21st, 2009
I have mobile connect working...I think :-)
Can call the deskphone and cell phone rings. I then pickup the call on cell, disconnect and can reterieve the call from deskphone.
At this point can I now bounce the call between cell and desk phone, is this a feature of Mobile connect. I can transfer the call to cell, but don't see how I can reterieve the trasnfered call on the deskphone.
Another question is that can I be on a conversation on the phone and then send it to the cell phone without using the transfer button. I guess the language "in progress and in coming" calls are confusing. Does in progress mean the call is connected?
Maybe a summary of how mobile connect works will be helpful. I am just trying to make sure that if I have enabled it that I am using it properly. Last thing I want is for some smart end user to read up some docs and go ...hey!!! our phones aren't doing that
htluo Mon, 09/21/2009 - 09:47
  • Red, 2250 points or more
To transfer call from cell phone to desk phone:
1) You tell the other party that you're going to transfer him.
2) You hang up the cell phone.
3) On your desk phone there will be a call being on hold.
4) You press "resume" button on desk phone.
To transfer the call from desk phone to cell phone, you have to use the "Send to Mobile" button.
Michael
http://htluo.blogspot.com
Jonathan Schulenberg Mon, 09/21/2009 - 18:03
  • Cisco Designated VIP,
    2017 IP Telephony
The correct way to "transfer" a call to your remote destination is to use the Mobility soft key. This should be added to your soft key template if you haven't already done this. Using this instead of the traditional transfer will keep the call anchored on your DN for retrieval.
Also, in UCM 7 Mobile Connect got two noteable enhancements:
-Time of day based ACLs.
Example: Extend calls to the remote destination only between 8AM and 5PM. In 6.x, this was only possible based on ANI information.
-Enable/Disable through Mobility Soft Key.
Your only option in UCM 6.x from the Mobility soft key was to send an connected call to your remote destination. In 7.x, the user can now turn the feature on/off as desired.
