Device manager
Sep 21st, 2009
I have a pix 501 running Device manager 3.0(4). Just recently I am unable to bring the manager up in Explorer. It takes my two passwords and then hangs before the device manager window pops up. I tried differnt machines and browsers with the same results. Thanks Bob
mark.j.hodge Tue, 09/22/2009 - 03:23
Have you recently updated Java on your machines? PDM is very sensative as to the version it works with.
jagadeeshan.s Tue, 09/22/2009 - 04:03
As Mark told, PDM is very sensitive to java version. Try with java v1.5 or earlier version.
bobm_1010 Tue, 09/22/2009 - 05:44
Thanks guys, I found that if you go into the Java Icon in control panel you can disable/enable differnent versions of JAVA. I just turned off the latest version and it worked. Thanks Bob
