Warning message
Block all calls not from a specific calling number
Sep 21st, 2009
  • Silver, 250 points or more
I've seen plenty of examples of using translation rules to reject calls from specific calling numbers. However, I have a need to block all calls except those from a specific number. So I'm looking for a way to accept calls only from 1 number and either block all others, or send all others to a different number.
What's the best way to accomplish that? I'm using an PRI, H.323 gateway and CCM 4.
thanks,
Will
paolo bevilacqua Mon, 09/21/2009 - 11:01
  • Hall of Fame,
    Founding Member
something like
voice translation-profile bad-number
translate called 10
voice translation-rule 10
rule 1 /.*/ /666/
dial-peer voice 100 pots
answer-address 5551234
dial-peer voice 200 pots
answer-address .
translate incoming bad-number
Do not use "incoming called-number" on any pots DP or that will override answer-address.
will.alvord Mon, 09/21/2009 - 12:02
So there's a single PRI with a hundred plus DID's. I'm using incoming called-number . on the inbound pots dial-peer.
I only want to filter calls to a specific DID though, so I can't remove the incoming called-number .
paolo bevilacqua Mon, 09/21/2009 - 12:49
  • Hall of Fame,
    Founding Member
You replace "incoming called-number ." with "answer-address ."
Both are generic statements enough to match the incoming DP, that's all what matters.
On the generic one then put a reject rule for the specifi calling number.
Forgot to mention all DP's will need "direct-inward-dial"
will.alvord Mon, 09/21/2009 - 13:33
Would I use answer-address . on the inbound pots peer and answer-address . with the translation-profile referenced on the voip peer? Obviously I don't want to reference the translation-profile on the inbound pots peer.
paolo bevilacqua Mon, 09/21/2009 - 13:43
  • Hall of Fame,
    Founding Member
Do not use any translation outbond.
Just translate any called number inboud.
will.alvord Mon, 09/21/2009 - 13:51
It's been a really long and hectic day, so sorry if I'm being thick.
I want to filter inbound calls to a single # of over 100 #'s coming into a PRI -- so that the 1 # will only accept calls from 1 calling #.
It seems that if I make your changes, I'll be filtering calls to every # rather than just the 1. What am I missing?
thanks,
Will
paolo bevilacqua Mon, 09/21/2009 - 14:24
  • Hall of Fame,
    Founding Member
You are right, my example above makes that all calls from 5551234 go to DN 666, that is something different, and even had a mistake.
For what you want:
translate called 10
rule 1 /666/ reject
direct-inward-dial
answer-address .
direct-inward-dial
