Amber/Green light
Sep 21st, 2009
I have 4 3560 (C3560-IPBASEK9-M), Version 12.2(37)SE1 and lights most of the lights go from green to Amber I looked at the interfaces they are set to AUTO AUTO neg@ 10half no crc errors
Mode botton is set system STAT.
I have several others switches same set up and I do not get this
Peter Paluch Mon, 09/21/2009 - 12:44
In the STAT mode display, the amber LED signalizes that the port is basically blocked and does not transmit data. A port can be blocked for various reasons, mostly because the STP protocol decides for whatever reason that the port should be moved to a blocking state. Read this document for more detailed information about the meaning of port colors:
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3560/hardware/installation/guide/higoverview.html#wp1059195
Do you also experience connectivity problems when the ports go amber?
Best regards,
Peter
jfeo Mon, 09/21/2009 - 13:47
There doesn't seem to be any connectivity problems.
The port is Alternating green\amber but I do not see any errors
this is from one of the interfaces that the ports is alt between green/amber
Queueing strategy: fifo
Output queue: 0/40 (size/max)
86748 packets input, 12563593 bytes, 0 no buffer
Received 388 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
197735 packets output, 32221264 bytes, 0 underruns
0 output errors, 1185 collisions, 1 interface resets
Leo Laohoo Mon, 09/21/2009 - 14:23
I noticed that this port has negotiated to 10/Half. This is the reason why you are having "1185 collisions". If you want to further "drill down" on this, use the command sh controller e . Most likely the amber-green are caused by collisions due to the half duplex.
Hope this helps.
jfeo Mon, 09/21/2009 - 14:27
That is correc this is connected to a media converter that is only 10/half
here is controller command
Transmit FastEthernet0/25 Receive
32221264 Bytes 12563593 Bytes
85809 Unicast frames 86360 Unicast frames
20327 Multicast frames 0 Multicast frames
91599 Broadcast frames 388 Broadcast frames
0 Too old frames 12530933 Unicast bytes
364 Deferred frames 0 Multicast bytes
0 MTU exceeded frames 24832 Broadcast bytes
656 1 collision frames 0 Alignment errors
346 2 collision frames 0 FCS errors
140 3 collision frames 0 Oversize frames
40 4 collision frames 0 Undersize frames
3 5 collision frames 1943 Collision fragments
0 6 collision frames
0 7 collision frames 5813 Minimum size frames
0 8 collision frames 2421 65 to 127 byte frames
0 9 collision frames 78316 128 to 255 byte frames
0 10 collision frames 31 256 to 511 byte frames
0 11 collision frames 152 512 to 1023 byte frames
0 12 collision frames 15 1024 to 1518 byte frames
0 13 collision frames 0 Overrun frames
0 14 collision frames 0 Pause frames
0 15 collision frames
0 Excessive collisions 0 Symbol error frames
0 Late collisions 0 Invalid frames, too large
0 VLAN discard frames 0 Valid frames, too large
0 Excess defer frames 1943 Invalid frames, too small
42615 64 byte frames 0 Valid frames, too small
28637 127 byte frames
102046 255 byte frames 0 Too old frames
22096 511 byte frames 0 Valid oversize frames
248 1023 byte frames 0 System FCS error frames
2093 1518 byte frames 0 RxPortFifoFull drop frame
0 Too large frames
Leo Laohoo Mon, 09/21/2009 - 14:47
Both Receive and Transmit shows moderate amount of collisions alright. The amber lights flashing from time to time is indicative of this. Is this the issue you are having?
jfeo Mon, 09/21/2009 - 15:05
yes the only problem is customer has 500 hundred of these switches and these 4 on the only ones doing it only differnce I found
WS-C3560-48TS-S doing it
WS-C3560-48TS-E not doing it
jfeo Mon, 09/21/2009 - 15:29
interesting
these ports are configured with
switchport mode access....
wonder if it from the terminals connected
jfeo Tue, 09/22/2009 - 11:21
Still not sure I now seeing this at 2 sites out of 200 all same IOS and hardware.
while using this command sh int stats error
Port Single-Col Multi-Col
Fa0/2 9563 5932
Fa0/3 3907 2809
Fa0/4 0 0
Fa0/5 9886 6393
Fa0/6 0 0
Fa0/7 280 184
I get this and these are the ports the amber/green light happens every other errors are 0
I shouldn't see a amber/green on Single-Col but not sure on Multi-Col
