ASA 5550 VPN Ipsec works but not able to browse the internet
Sep 21st, 2009
We have setup an asa 5550 with ipsec. When I have build up the vpn connection and then try to ping a external (internet) address it works but when I try to browse it will not work. Is this an firewall issue on the ASA?
Thx,
Marc
Collin Clark Mon, 09/21/2009 - 12:04
  • Purple, 4500 points or more
Marc-
Sounds more like a DNS issue, so let's check that first. Can you ping a site by name (ping slashdot.com)?
MJonkers Mon, 09/21/2009 - 21:51
Hi Collin,
I can resolve the ip address and i can ping the address. But I cannot browse.
Marc
MJonkers Mon, 09/21/2009 - 22:29
Hi Collin,
Futher testing reveals that the asa blocks returning traffic. I can see the traffic leaving our network to the internet and returning traffic entering our network. It stops at the asa.
I have enclosed the config file of the asa.
thx Marc
MJonkers Tue, 09/22/2009 - 02:05
Hi, I solved the problem. I had to add a tunneled interface on the inside network.
thx,
Marc
Collin Clark Tue, 09/22/2009 - 05:25
Marc-
Glad to hear you worked through it. Can you explain or give the command of your added tunnel interface?
MJonkers Tue, 09/22/2009 - 07:18
yes the command is:
route inside 0.0.0.0 0.0.0.0 137.120.xxx.xxx tunneled
Marc
