09-21-2009 11:25 AM - edited 03-11-2019 09:18 AM
Having issues passing traffic from one VLAN to the other VLAN through the PIX515e. I can access Internet through both VLANs but can not access one VLAN fro the other. Would appreciate some more eyes than just mine.
I have read the 6.3 docs. I also searched through this forum before posting. I am thinking this should be just like a DMZ setup since one VLAN has a lower security number than the other, due to version of code.
Obviously I am missing something. Thanks in advance for any help.
09-22-2009 03:28 AM
Which vlan cannot communicate with which vlan?
09-22-2009 04:34 AM
None of the 3 VLANs can talk to the other VLANs. I can put a PC on any of the VLANs and PING the firewall, which is set as the gateway. However, no traffic will pass between any of the VLANs.
09-22-2009 04:36 AM
I see from your post - you have a restricted license, I suggest you look into the limitations on physical & logical interfaces for your platform.
09-22-2009 04:37 AM
Limitations are 3 physical and 5 logical. I am within the limitations.
09-22-2009 04:44 AM
what do you debugs & logs tell you when you try to connect from one vlan to another?
09-22-2009 06:38 AM
PINGs go no further than the VLAN interface on which they are received.
PING from PC 172.16.1.10 to PC 172.17.1.10 hits 172.16.1.1 and stops.
I can however get out to the Internet from both VLANs with no problem. I can not get from VLAN to VLAN. I believe my access-lists are correct, but still no traffic is being passed.
09-22-2009 06:40 AM
what do your logs say - they will likely indicate the issue
09-22-2009 07:01 AM
Sorry, I was not clear. I ran a "debug packet" on all three interfaces while running the PING test.
The debugs showed the PINGs hitting the VLAN interface and stopping.
09-22-2009 07:05 AM
Can you post the debug output?
09-24-2009 08:27 AM
I have not abandoned this, but it may be tomorrow before I can get back to it. Thanks for you effort and help.
