IPCC Express
Sep 21st, 2009
Hi All,
I've changed CSS and partition in CTI RP and jtapi phones in CUCM and in IPCC express. since then, when I call CTI RP, I receive busy tone. any suggestion would be very appreciated.
Overall Rating: 4 (1 ratings)
Marwan ALshawi Mon, 09/21/2009 - 14:06
from where u did change it CCX or CCM ?
cisco recommened to change it from CCX
then go CCX admin and re synic the CTI and ports as well
good luck
hugemongus Fri, 09/25/2009 - 05:25
You can check and/or resync from there.
You may want to do this during non-peak times. Once the sync starts, just let it run.
