Lost config in nvram
Leo Laohoo Mon, 09/21/2009 - 15:03
Does it loose the config if, say, you reboot the switch too? Check the config register.
glen.grant Tue, 09/22/2009 - 03:17
I have seen it happen when you take a power hit , it then starts to reboot and takes another quick power hit . It may be something like that , you can test if you have downtime by just normally powering off and then powering on a couple of times , if it boots normally that may be whats happening but I am not sure there is any way around it unless its critical then you need to look at UPS's to keep that from happening.
YANGCCIE4 Tue, 09/22/2009 - 08:16
# dir flash
OR
#sh flash
you may have a config file in your flash.
hope it help
Yang
