Restricting telnet/ssh access to loopback address
Sep 21st, 2009
I've been requested to restrict telnet/ssh access to the loopback address only.
I've been attempting to do this using access lists however the access lists either block access to all interfaces or allows access to no interfaces.
Any and all help in this is appreciated.
Below are the configs I have been trying. This is for telnet only.
! loopback address I want to restrict access to
interface Loopback0
ip address 10.20.254.1 255.255.255.255
! interface not to be able to telnet to
interface FastEthernet0/0
ip address 10.20.10.1 255.255.255.0
!access-list 101 in is applied to line vty 0 4
line vty 0 4
access-class 101 in
!Below gets to both interfaces
access-list 101 perm tcp any any eq telnet
access-list 101 deny tcp any any
sh access-list 101
Extended IP access list 101
10 permit tcp any any eq telnet (4 matches)
20 deny tcp any any
!The below stopped both interfaces being accessed.
access-list 101 perm tcp any host 10.20.254.1 (loopback address) eq telnet
sh access-l 101
10 permit tcp any host 10.20.254.1 eq telnet
20 deny tcp any any (2 matches)
1 vote
Overall Rating: 5 (3 ratings)
Joe Clarke Mon, 09/21/2009 - 17:23
You can do this with control-plane policing (CoPP). For example:
access-list 101 deny tcp any host 10.20.254.1 eq telnet
access-list 101 permit tcp any any eq telnet
access-list 101 deny ip any any
class-map match-all matchtelnet
match access-group 101
policy-map filtertelnet
class matchtelnet
drop
control-plane
service-policy input filtertelnet
Note: the ACL above looks like the opposite of what you want, but really you're matching traffic you do NOT want, then dropping it in the policy-map.
The net effect will be that all TCP traffic is allowed to this device OTHER than tcp/23 traffic unless the destination address is 10.20.254.1.
boxhallbr Mon, 09/21/2009 - 18:50
Fantastic. I'm still trying to get my head around it but it works. Need to look at the backward logic.
Thanks for help.
boxhallbr Tue, 10/13/2009 - 16:27
You supplied the above answer last month and, when I tested it on a 1841 router it worked fine.
My problem is when I tried to apply it to a 3750 layer 3 switch. The drop command on the policy-map didn't take nor did the service-policy input command on the control-plane (output below).
Any and all help will be appreciated.
router(config-cmap)#policy-map filtertelnet
router(config-pmap)#class matchtelnet
router(config-pmap-c)#drop
% Invalid input detected at '^' marker.
router(config-pmap-c)#control-plane
router(config-cp)#service-policy input filtertelnet
QoS: policymap is supported on physical, VLAN, and ES interfaces only
Service Policy attachment failed
error: failed to install policy map filtertelnet
router(config-cp)#
Joe Clarke Tue, 10/13/2009 - 16:42
Control-plane policing is not supported on the 3750 platform. This solution will not work there.
boxhallbr Tue, 10/13/2009 - 16:59
Thanks.
Is there any other way of restricting remote access to single interfaces on the 3750 switches?
Joe Clarke Tue, 10/13/2009 - 17:09
Interface ACLs are the only other way to go. Create an ACL that only permits telnet to the desired interface, then apply it to all IP interfaces on the switch.
boxhallbr Tue, 10/20/2009 - 15:23
Joe,
Tested the access list on a test box and it work fine. Before I start applying it on all devices thought I would get you to have a quick look.
Does the below look correct?
Want to connect to IP address 10.1.112.5.
ip access-list extended RemoteAccess
permit tcp any host 10.1.112.5 eq telnet
deny tcp any any eq telnet
permit ip any any
Then apply the access list
interface Vlan210
ip address 10.2.112.5 255.255.252.0
ip access-group RemoteAccess in
interface Vlan410
ip address 10.1.112.5 255.255.252.0
Thanks again for your help.
